Protocol RIB Abstraction Layer has failed to allocate resources to track a route flap dampening penalty against a BGP route. A penalty will not be tracked against the withdrawn route. If the route is flapping, then Protocol will attempt to allocate a penalty CB the next time the route is withdrawn.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Warning
The Protocol RIB Abstraction Layer has failed to allocate resources to track a route flap dampening penalty against a BGP route. VR = %p1% Route <AFI, SAFI> = <%p2%, %p3%> Route prefix length (bits) = %p4% Route prefix = %p5%
| Name | Type |
| p1 | uInt32 |
| p2 | uInt16 |
| p3 | uInt8 |
| p4 | uInt8 |
| p5 | HexByteArray |
